Vernier compatibility - Printable Version +- Caliper2PC (https://www.caliper2pc.de/forum) +-- Forum: English (https://www.caliper2pc.de/forum/forumdisplay.php?fid=4) +--- Forum: Hardware (https://www.caliper2pc.de/forum/forumdisplay.php?fid=5) +--- Thread: Vernier compatibility (/showthread.php?tid=16) |
Vernier compatibility - Besnik - 04-14-2019 Hello Guys, On Harold Hall's interesting website I found this digital vernier mounted on a lathe. The vernier has a big LCD display so that it is used as a digital readout by itself. I would like to know if this kind of verniers are compatible with the Caliper2PC interface. Does anybody know which protocol it uses? RE: Vernier compatibility - Ben - 04-15-2019 Hi Besnik, We will have to check if this type of caliper has a data port at all. I am not sure it has. ![]() Does anybody know? RE: Vernier compatibility - Tomer - 04-16-2019 According to pictures of this type of caliper there seems to be no opening for a data port. However some calipers have a data port with soldering terminals on the PCB even if there is no opening it the plastic housing (see picture). ![]() To find out, one have to disassemble the caliper and take a look at the PCB. |
